Need helps... cars running like crap
Old 11-17-2004, 05:05 PM
Phirantes
Phirantes's Avatar
Default Need helps... cars running like crap
well actually it idles quite nicely however when i step on the gas, it's a different story. and just to get it outta the way, i just cleaned and gapped sparkplugs and replaced fuel filter but that didn't help... ok here goes. like i said car idles great, and any soft acceleration is flawless. the problom comes when i try to step on it or if i get lazy and don't down downshift i wanna accelerate from low rpms (by low i mean like 1500-2000) whenever i do it my engine runs really rough. makes the whole car shake, but it's odd because it's a very uneven roughness/studder. when i get on the gas it studders a bit, then the car will lerch foward cause all the engine power will come back and it will run fine, then after like a second it will studder again... mainly happens in the low rpm range (and no i'm not bogging it down)... not as noticable in high rpm range but i can tell power is missing, my third gear feels like fourth. any help would be great !
Phirantes is offline
Old 11-17-2004, 05:34 PM
Phirantes
Phirantes's Avatar
Default RE: Need helps... cars running like crap
well after searching the forums, i noticed tons of ppl have had the same problem, i guess i'll look in to replacing the MAF and putting in some 93 gas, thanks for all the help j/k if anyone has new news about the problom though, lemmie know
Old 11-17-2004, 08:37 PM
Chopper
Chopper's Avatar
Look a for a vacuum leak.93 octane will do you no good.This sounds like plug wires(if you had any)Go to Advance or Autozone and get it checked for codes.
Chopper is offline
Old 11-19-2004, 04:10 AM
96GT70SS
96GT70SS's Avatar
1 of 3 things....and im fairly certain, one of them hits the nail on the head!
1- wires/ wire configuration......are you sure u have the wires on right>? it sound like a misfire (obviously) and im not so sure u put em on right....no offense. if it is the wires, plan on putting in ANOTHER set of new plugs....they are probably soaked by now....of corse u could take the old lighter and burn em...but not too much or you'll ruin the electrode
2-mass air. but i doubt it considering you car is almost brand new...well...yes, very new....mass air goes out like once every 10 years
3-bhg. probably not, but if it overheats at idel or has rough acceleration under load...as in it feels like you dropped the clutch a little too soon and your neck jerks back and fourth.....eiiii!
96GT70SS is offline
Old 11-19-2004, 09:52 AM
Chopper
Chopper's Avatar
In addition to my first post on this subject,try checking the fuel pressure.It could be a weak or dying fuel pump.
Chopper is offline
Old 11-19-2004, 11:33 AM
Soaring
I ♥ Acer
Soaring's Avatar
Take it to a Ford mechanic. You are prolly still under warranty.
Soaring is offline
Old 11-19-2004, 11:44 AM
Phirantes
Phirantes's Avatar
woo thanks guys, i'm gonne do what chopper said check the fuel pressure, it definately feels like some kind of fuel restriction, and since changing the filter didn't work i'll try the pump.... if not that next will be the MAF, whats on it now is a K&N MAF that came with the FIPK but i didn't put it on, the previous owner did. Hopefully i'll have the problem diagnosed by the end of the weekend, and i'll let everyone know what was wrong since this seems to be a rampent problem. thanks
btw when you get ready to start the car after it's set a while, oh say over night, do yall hear the fuel pump come on to pressurize. I don't, and i don't know if its just THAT silent or if mine is going out.
Old 11-19-2004, 11:59 AM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
I've never heard my fuel pump prime...
Dan04COBRA is offline
Old 11-19-2004, 12:34 PM
ponygt
ponygt's Avatar
it's a pretty silent pump, if you keep your radio off, windows closed, turn the key on (engine off) and you'll hear a noise. thats the fuel pump, even though it doesn't quite sound like one. and also if you ever hear the sound of something like a fan slowing down when you shut your car off after a while of driving, it's the fan for your eec-v.
ponygt is offline
Old 11-19-2004, 12:36 PM
ponygt
ponygt's Avatar
if it is a faulty fuel pump, you're lucky it's a breeze to replace. if you do change it, here's a chance to put higher flowing pump in.
ponygt is offline
djbigskrilla
09-20-2022 01:04 AM
jjwinel78
08-17-2015 03:34 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
89blueslug
08-10-2015 07:20 AM
Quick Reply: Need helps... cars running like crap
