surging/feels like car is missing
ok when im driven when the car is warmed up going about 30-35 in 4th gear between 1500-2000 rpms i think, when i barely hitten the gas to stay at the speed limit the car will fill like it is missing bad but i got new plugs and wires on the car. BUT i think i need a IAC because when the car warms up they rpms will go up and down between 1k to like below 500rpms which is weird to me.
RE: surging/feels like car is missing
hehe sounds like the thread i just put up... i'm having the same problem dude, and i know that it's not bogging down the engine, it's just easy to feel when the rpms are that low and you step on it....the loss of power sucks... theres a couple of things i'm gonna try like running some 93 gas and look at getting the MAF replaced if you wanna read some past threads on the problem , go search for "fuel filter" and you'll get a whole bunch of threads that have had the same problem
Check for a vacuum leak.93 octane gas will do nothing for you.Using a higher than recomended octane can cause a buildup of deposits in the combustion chamber.Look at the IAC also.
i changed the fuel filter, and it is getten worse, and i cleaned the IAC but it didnt help with anything but i have a check engine light for that canister code bull **** i tryed fixing that, but no luck, and this blows GOD DAMIT [:@]and i need to change an O2 senor but i dont think that has nothin to do with it
my car did the same exact thing and i tried all the same stuff and i replaced the throttle positioning sensor, still same problem so i bought a fuel pressure gauge and tested it , had to replace the fuel pump fixed it right up not hard to do either
hope this helps
hope this helps
DrunknRuckus
08-23-2015 10:05 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
