Stereo Question
RE: Stereo Question
Read this, it may help, and its Metra Harness 70-5519
https://mustangforums.com/m_2553296/...tm.htm#2553296
RE: Stereo Question
ORIGINAL: bullitt5561
RE: Stereo Question
My my own experience, i put a new head unit in and left the rest of the mach system in. You can actually run speaker level inputs to the stock mach460 amps so you have the power of the head unit plus thepower of the mach 460. JMO
RE: Stereo Question
ORIGINAL: jst854
RE: Stereo Question
These are also the harness that you will need, I would recomend doing it yourself, its not that hard and I would not trust someone else working on my car, If something is screwed up i would feel better if i did it myself. These are the wiring harness that will work for you. This will power your radio http://www.cardomain.com/item/SCOFD08B?vq_id=none. While this harness will give you speaker level inputs to your stock amps http://www.cardomain.com/item/SCOFD06BGood luck and let us know what you plan on doing
RE: Stereo Question
ORIGINAL: jst854
RE: Stereo Question
Thats cool man, I just like putting things on myself. I would also talk to them so that they wire it up so that you can play dvds with out the parking brake. Head units that have dvd players have a wire that you are supposto wire to the parking brake so that you can only watch movies while the car is not moving.
RE: Stereo Question
ORIGINAL: jst854
RE: Stereo Question
cool man good luck with everything, If you cant get it done its really easy all you need to do is hook the wire up to the ground. let me know if this is the case and i will help walk you through it.
RE: Stereo Question
ORIGINAL: jst854
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
