4.6 stroker
4.6 stroker
i am buildinthe motor inmy 97 gt i already have full bolts on for it,and i bought a short block stroked to a 5.0 also pi heads pi intake manifold and stage 3 cams. i have everything else that goes along with the parts. iam just not sure wat the stroker kits will do how much power iam i lookin at
RE: 4.6 stroker
ORIGINAL: 97stang33
i am buildin the motor in my 97 gt i already have full bolts on for it, and i bought a short block stroked to a 5.0 also pi heads pi intake manifold and stage 3 cams. i have everything else that goes along with the parts. iam just not sure wat the stroker kits will do how much power iam i lookin at
RE: 4.6 stroker
ORIGINAL: ZW99GT
Stage 3 cam and ported heads is gonna run well. Stroker kit when running on motor, wont really do anything over stock displacement. If you put boost to it, it will help out.
RE: 4.6 stroker
ORIGINAL: racer02GTstang
i hope they do for the price of them.... lol
ORIGINAL: ZW99GT
RE: 4.6 stroker
ORIGINAL: Hash06
stage 3 cams? that is huge i hope the bottom end is forged to be able to put those cams to use
ORIGINAL: 97stang33
To the orginal poster, make sure you have everything lined out. If you have a higher compression shortblock with non notched pistons (or even if you don't) the very first thing your gonna want to do when you get the cams in is check for PTV... even then be careful. The guy that built ZW99GTs engine went thru 2 or 3 of them because of rod strech and problems with PTV.
RE: 4.6 stroker
ORIGINAL: 2000GT4.6
If its a stroker it almost has to be able to take the RPM, being an afttermarket shortblock.
ORIGINAL: Hash06
ORIGINAL: 97stang33
And b/c of the problem, I have ~2 extra cubic inches for boreing out .030the damage, and stronger Probe pistons. lol
10-09-2015 03:27 PM
