The Bucket is heading to El Paso
I spoke with Brian today and the Bucket will be heading to his shop for a freshen up and dyno time on the engine. Hopefully, it will only be new rings, gaskets and bearings. The Bucket is back on the road to recovery.THANKS Brian.
RE: The Bucket is heading to El Paso
ORIGINAL: racer02GTstang
how did the rings go on that motor with that low of mileage on the motor??
ORIGINAL: code3GT
Loooooong story. The short version is that a shop did some work on it, forgot to tighten some intake bolts and the cylinders got a boat load of coolant dumped into them.
damn, that sucks... is that when you had some of the sensors replaced?.. did it do anything to the block or heads??
ORIGINAL: code3GT
ORIGINAL: code3GT
We are hoping everything else is fine. The car fell off after the 1/8 and I just parked the car until I could figure out what was wrong.
ORIGINAL: code3GT
how much do you think it will cost you for the new rings and gaskets and such?? also, do you know of anywhere i can get only the front crank seal??
ORIGINAL: code3GT
ORIGINAL: code3GT
