Braking
RE: Braking
my g/f just had this problem with her car (including the severe shaking), i thought it was the rotors as well, but as i inspected the tire, the inside tread of her tire was completely gone. check the tires as well just to be sure, but itis most likely a warped rotor.
RE: Braking
Chances are, you won't get any help.. There are 3 B's that usually are NEVER covered under warranty.. You may get lucky though..
Brakes
Batteries
Belts
YRMV..
JT
Brakes
Batteries
Belts
YRMV..
JT
RE: Braking
ORIGINAL: GodAmGT00
Brakes
Batteries
Belts
YRMV..
JT
Brakes
Batteries
Belts
YRMV..
JT
RE: Braking
ORIGINAL: ponyrideGT2004
Yeah but I only had the car for just over a month. That shouldn't be mywear & tear problem. No one can wear the brakes or tires in a month unless you excessively do burn outs. I want to save the burnouts for the track.
ORIGINAL: GodAmGT00
Brakes
Batteries
Belts
YRMV..
JT
Brakes
Batteries
Belts
YRMV..
JT
RE: Braking
why spend almost 200 bucks on rotors + install when you can get the 13" Mach 1 brake kit from buyfordracing.com for $300? it includes the 13" brembo rotors, calipers, pads and braided stainless brake lines......when my fronts are worn out again that is what i am doing. then painting the new calipers and stock rears so they all match.
RE: Braking
ORIGINAL: laserred38
RE: Braking
ORIGINAL: SmallFeesh
+1 the dealership is supposed to make sure the car is tip top before selling it!
They may hook it up, but don't be pissed if they don't..
JT
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
