mil eliminators help
[:@] well i recently purchased a 99 gt and got the bassani off road x pipe and also got the mil's. but the thing that pisses me off is that on the passenger side it did not fit. so do any of you guys know how to fix the problem that i am having?
RE: mil eliminators help
I just did this..the passenger side o2 plug's 2 alignment tabs did not line up with the slots in the mil plug. take the o2 sensor plug and grind off the 2 tabs. I used a electric grinding stone. Or a dremel tool. Took like 30 seconds. Slid right together after that. Good luck, it's easy.
ok i will try it out and i will let you know how it went. but aren't all the o2 sensors the same? or is it easier to purchase another driver side o2 and put it on the passenger. or is it two different connections from the passenger to the driver side?
trashxtrash
09-20-2015 10:49 PM
09-17-2015 07:57 PM
