Twin turbo non pi track vid.
#32
RE: Twin turbo non pi track vid.
ORIGINAL: yoteehunter
405rwhp 427ftlbs.
I posted a sheet on a thread a while back that sheet was from the third to the last run. Anyways please feel free to through all the ideas you can at me about what to do for launching. I like the idea of taller slicks and stiffer gears, I just have to not go to steep because the turbos like to spool under load and gears will take away from that a bit. Maybe like 3.55 or with same size tire just shorter rim like welds or soomthing. My dad is reading up on suspension, he will be helping me sort that out since I somehow neglected it while I was building the turbo system.....lol $$$$$
ORIGINAL: czwalga00gt
How much rwhp?
How much rwhp?
I never beat on my car (I tell everone I drive it like a girl) and I ran a 13.3 @ 104 with no real HP boltons (230hp) with stock control arms, I did get the power to the ground and that's what it's all about. And on a 100 shot I still had less HP than you and would run 12.0's all day and trapped @ 116mph.
As for a taller slick, only move up to a taller slick when you NEED (which you don't)it or it will slow you down. If you are not running out of gear or in need of a taller sidewall for some extra hook than don't do it.
The best thing you can do is concentrate on making yourself a better racer and geeting the power to the ground. Remember that once you put the power to the ground things start to break (clutch, torque boxes, axle tubes and the list goes on.)
#33
ORIGINAL: 96 myztic
the 60ft, nor the ET is based on when you leave off the line, those clocks are only started once the front tire begins to roll
JT
#35
I forgot to mention.. You won't build boost by just launching at a given RPM.. Remember, turbos only build boost when there is load introduced, since you need a good amount of exhaust velocity to spin that bastard enough...
I asked about the ignition system, but MSD has the ones that you can change your Rev-limiter, to an effective RPM that you want to launch at... It's also known as a Stutterbox, or.. I can't remember the other name... You'd just sit w/ your clutch down, and the car floored, and when the lights come down, just dump the clutch... I've you've got good slicks, or tires, then the car will stick and you'll be fine...
But nothing beats practice.. I'd say by the end of the summer, if you go at least once a week, then you'll easily have low 12's..
JT
JT
#37
ORIGINAL: Dan04COBRA
No pics of the Turbos? They were pretty silent..
#38
[quote]ORIGINAL: GodAmGT00
How about not sleeping at the line?? [8D]
The best thing, especially when you're traction limited, is to jump at the last yellow light.. I know, I know, it's been said before, but that's a sure way of making sure your tires are planted by the green.. On top of that, when you get better tires, you can start launching at a much higher RPM..
What kind of ignition do you have??
I wasnt sleeping .....each time I was slipping the clutch.....trying different rpm and not paying much attention to what the other guy was doing really I was just trying to get the car to launch. The clock starts after you roll past the beam and frankly I didnt care what my reaction time was I was just trying desperately to launch for a good time.
#40
ORIGINAL: 96 myztic
i would say 3.73 at least if you are doing a gear change with the same tires you got now, but you also have to remember that if you get big wall slicks, it will lower your effective gear ratio, bringing a 4.10 down to that of a 3.73 or there abouts.
Getting a nice set of lower control arms with a soft supsension to really get some weight transfer is gonna see those 60 fts plummet in combination with some slicks. Each tenth dropped in the 60' equates to 2 tenths on the ET, so the launch is very important.
What kind of RPM are you launching at and what rpm are you crossing the traps at, that would aid in the gear selection a whole lot. Is there any efficient way to brake boost, like heal-toe the gas/brake and ride the cluth to try and build some boost off the line?
