bad mil's?
bad mil's?
so im pretty sure my mil's are bad, but just wanted to find out for sure before i start ordering parts. i just installed my o/r x with mil's (both used) yesterday, and after a few hours the service light came on. i checked the mil's this morning and all the connections seem to be fine. there's a red indicator light on the mil and when the car is started the red light blinks. i'm going to autozone this afternoon to get my codes cleared, but does this mean the mil's are running properly or they aren't working at all? thanks
RE: bad mil's?
ORIGINAL: 99shadowGT
RE: bad mil's?
just got the codes cleared and it was the rear o2 sensor bank 1 and air ful meter, im guessing that was just because of the o2 sensor. light hasn't come on and i drove it for about an hour so hopefully it doesn't come back on...the guy at autozone said if you disconnect the + connection on the battery the codes will clear, is this true? thanks
RE: bad mil's?
ORIGINAL: Brute03
yes, if you disconnect it for a few minutes it'll resetthe KAM, but everyone usually disconnects the negative terminal instead
RE: bad mil's?
Or you could try this http://www.scoobymods.com/forums/showthread.php?t=5468
Has anybody tried this?
