how 2 tell whats killing my battery?
Old 04-03-2007, 06:22 PM
mariotraci
mariotraci's Avatar
Default how 2 tell whats killing my battery?
i have an ohm meter, i just need to know how and where to start.
thank you
p.s its a new battery. it takes about to days to die
mariotraci is offline
Old 04-03-2007, 09:26 PM
bluepony4.6
bluepony4.6's Avatar
Default RE: how 2 tell whats killing my battery?
I discovered that my rear window defroster was killing my battery about a year ago. I would turn my car off and the next morning the battery would be dead or slow to start my car. I was cleaning my rear window one day in my garage and the window was hot and my car keys were in my pocket. I looked in the car and my defroster light was on. I just disconnected the two connectors in the rear window and took out the fuse.
bluepony4.6 is offline
Old 04-04-2007, 10:51 AM
mariotraci
mariotraci's Avatar
i heard something about putting a ohm meter on the battery and start pulling fuses.i just need to know what setting to put the ohm meter on and what draw should be with the key off.
Old 04-04-2007, 09:30 PM
mariotraci
mariotraci's Avatar
[sm=helpout.gif]
Old 04-04-2007, 10:46 PM
undecided.steve
undecided.steve's Avatar
ORIGINAL: mariotraci
You have to put the meter in SERIES with the battery and it should be set to measure DC Current.
Then you start pulling fuses and see when it drops to the normal range which for most cars should be somewhere around 25 milliamps or so.
If it's more than 100 milliamps you have a problem.
Most fuses however control more than one circuit so now you have to figure out what circuits that particular fuse controls and troubleshoot from there.
If you have no idea what I am talking about, you might be better off having someone with electrical troubleshooting knowledge assist you because you can cause some very serious and expensive damage to your car.
undecided.steve is offline
Old 04-04-2007, 10:48 PM
blueherd02gt
blueherd02gt's Avatar
Does the battery have a warranty? Maybe you have a bad one
blueherd02gt is offline
Old 04-04-2007, 11:21 PM
JacobTheSnakob
JacobTheSnakob's Avatar
Check your power seat buttons. I had one stick on me one time and it took me a week to figure out what was draining mine.
JacobTheSnakob is offline
Old 04-05-2007, 12:08 AM
mariotraci
mariotraci's Avatar
well i think it the mach stereo but im no sure.So im try to pen point one area.
Old 04-05-2007, 02:31 AM
BuzzCut
BuzzCut's Avatar
ORIGINAL: undecided.steve
+1
BuzzCut is offline
Old 04-05-2007, 03:21 AM
Tylus
Tylus's Avatar
is the glovebox light on? their sneaky little things
other than that, I'd do what undecided.steve said
Tylus is offline
Quick Reply: how 2 tell whats killing my battery?
