Can you do stage 2 cams without a stall converter?
Can I get stage 2 cams without a stall converter on an Automatic? Or should I stay with stage 1. Or get a custom grind for the Nitrous? You can see my mods below.
RE: Can you do stage 2 cams without a stall converter?
You might be able to get away with it but it could have a hard time idling in gear, plus your leaving a ton on the table performance wise. You will get as much or more of an ET drop with the right converter than the cams.
trashxtrash
09-20-2015 10:49 PM
