I tried to see what rear end gear I have and..
The tag on the rear end said 3L28. Does that mean 328?? I wanted to know so I can look into getting a 390 and know that im not wasting my money. Maybe a 410, im not sure yet.
RE: I tried to see what rear end gear I have and..
I've got the same tag on my diff. I beleive it means 3:08 gear (according to a budy who's a service writer at a Ford dealership). I'm doing a 3:90 gear in my auto 2002 gt if that helps.
Ford 8.8 decoding info
Tag Code RyZZx88xxxx
y L = posi, not L = not posi
R.ZZ Ratio
88 Size (8.8)
x Not important
Ford 8.8" with drums is 28 splines axles.
There you go.
R.ZZ Ratio
88 Size (8.8)
x Not important
There you go.
No, you have a 3.27. The 28 is the number of splines not the number of teeth of the ring.
The ring has 32 teeth and the pinion has 7 I believe
where the 4.10's has 41 teeth on the ring and 10 on the pinion.
