Noises From The Rear
Old 04-04-2007, 12:23 PM
96mustanggt55
96mustanggt55's Avatar
Default Noises From The Rear
Ok so I am getting squeaking noises and a slight vibration throught the car. The noises are coming from the rear end of my car. I have allready Clean the gears and replaced new gear oil and additive. When my RPM'S are low in 5th gear and I press the Gas pedal down on the Highway my rear begins to squeak. It also does this just crusing around in any gear. I also get a small vibration throught the whole car when i am driving. Does anyone have any ideas or suggestions. Because i am about ready to get rid of the car before it completly ies on me. Please Help Me!!!!!
96mustanggt55 is offline
Old 04-04-2007, 01:07 PM
GodAmGT00
GodAmGT00's Avatar
Default RE: Noises From The Rear
How are the bushings on your rear control arms, both lower/upper?? You may have a bad rear diff, but can you give us more info, like what kind of squeak?? Are you confusing a squeak w/ a whirring?? Have you had the wheels off recently?? Did you remember to torque the lugs after you put the car on the ground??
JT
GodAmGT00 is offline
Old 04-04-2007, 01:28 PM
96mustanggt55
Yea the lugs are deff. tight. I got a new set of wheels put on and they were impacted back on. What do you mean by whirring? Im Just not sre what you mean by that. I will have to look at the Bushings when I can. Due to rain In my area today. I dont have a garage to put it in. to me it sounds like a squeak It is pretty high pitched.
bjdutch2005
03-24-2017 03:38 AM
robjh22
Suspension
09-08-2015 12:47 PM
Emblazoned
09-03-2015 10:45 PM
09-01-2015 08:16 PM
Quick Reply: Noises From The Rear
