would i even feel a difference?
RE: would i even feel a difference?
Only if the install sucks.
lets just get all your questions out of the way right away (since nobody can apparently use the search function lol):
Get either 3.73s or 4.10s. the RPM on them isn't that much different between them.
They won't whine if properly installed. if they do, the install is wrong and you need to get the shop to redo it as its going to destroy the rearend (re: use a mustang performance shop, not a dealer).
They won't reduce your top end, more than likely it will increase.
MPG will not be that badly effected IF you keep your foot out of it. Most people hardly see even a 1 MPG drop.
There are basically no downsides (other than a small MPG drop) to doing gears. You will also need something like a handheld or a speedcal to fix the speedometer.
ORIGINAL: jt01gt
I totally forgot about the speedometer f-ing up, I had 373s in my 96 and no one I asked knew what to do to fix that.
[align=left][/align]
Don't forget about 3.90's or 4.30's- there are a TON of threads about this... 3.73 vs 3.90 vs 4.10 vs 4.30... If you're staying N/A and not planning any nitrous or anything - i'd say to get 4.30's... but search the forum for the gear threads... trust me they're out there.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
09-08-2015 11:50 AM
