Torque specs on intake manifold?
Old 04-05-2007, 02:44 PM
RipTide7
RipTide7's Avatar
Default Torque specs on intake manifold?
Anybody know em?
RipTide7 is offline
Old 04-05-2007, 02:45 PM
mvr
mvr's Avatar
Default RE: Torque specs on intake manifold?
http://www.muscularmustangs.com/2005/torquespecs.php
mvr is offline
Old 04-05-2007, 02:51 PM
RipTide7
RipTide7's Avatar
Thanks
RipTide7 is offline
Old 12-27-2017, 02:45 PM
ironwarrior
ironwarrior's Avatar
Default Proper Torque for 2001 GT Mustang PI Intake Manifold Bolts
Why do the manuals vary so much in recommended Torque spec for a 2001 GT Mustang PI Intake Manifold.
My Haynes Manual suggests 18 FT LBS
An Online Video I watched recommends 18.5
Other Specs Posted Online show from 15-22 FT LBS.
Which is the correct torque?
I am thinking go with the 18.5 and perhaps re-torque when hot after assembly to 20FT LBS...
Any suggestions?
Thanks...
ironwarrior is offline
Old 12-27-2017, 04:16 PM
WJL
WJL's Avatar
There is also a sequence
https://static.summitracing.com/glob...20manifold.pdf
WJL is offline
Old 12-27-2017, 08:37 PM
Z28KLR
Z28KLR's Avatar
Follow the sequence as noted in the above post. Just make your life simple and shoot for 18-ish. A lb or two either way from that number is of no consequence and there's no need to re-torque or anything later. Not sure which type of wrench you're using but I prefer a beam for this particular task.
Z28KLR is offline
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Torque specs on intake manifold?
