Need help with this repair
04-05-2007, 08:00 PM
Does anyone know what i would need to do to fix this problem.... the little nozzles where the windshield wiper fluid is, the driver side works but the passenger side doesnt, what could cause this and if its not just clogged, what would i need to do to repair it
04-05-2007, 08:02 PM
I ♥ Acer
RE: Need help with this repair
Poke a needle through it.
04-05-2007, 08:05 PM
if its not clogged, is there a fuse or some kind of pump that could have gone?
04-05-2007, 08:06 PM
I ♥ Acer
If it was a fuse or pump, they both wont work.
04-05-2007, 08:11 PM
alright thanks for the help
04-05-2007, 08:14 PM
check and make sure your washer fluid is full. If the needle doesn't work then I guess you're out of luck.
04-05-2007, 09:29 PM
no, i dont think ill be out of luck, if it doesnt work ill find the problem
04-05-2007, 09:30 PM
maybe if you can remove the nozzle put it in some of that clr stuff there might be some type of buildup in there
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
2015Ecoboost
09-17-2015 01:48 PM
yourmom6990
09-14-2015 10:52 PM
rksnow1
09-14-2015 08:46 PM
