Diff Cover Sealant
Diff Cover Sealant
I'll be changing the diff fluid this weekend and I wanted to know what you all use for a sealant. I'm assuming just normal silicone sealant, but just wanted to check.
Also, I know its been a heated deabate about adding a friction modifier to the Royal Purple (or any other synthetic). What have you used, and have you had any problems?
Thanks
Thanks
RE: Diff Cover Sealant
The mechs at the garage I go to used RTV sealant. Also the ford specs mandate the use of the modifier with the recommended fluid. I called the ford service center to confirm the modfier and they stated it needs to be added to prevent problems with the gears down the road.
techsent
techsent
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
