60k Maintenance
RE: 60k Maintenance
ORIGINAL: kylebgt
Might want to invest in a new iac, I gaurantee that sooner than later it will need replacing.
Basic 60k maintanence,
coolant flush,
change the tranny oil< if you want
new spark plugs
new fuel injectors< if you want
oil change
new belts<if you want
check timing
check compression
coolant flush,
new spark plugs
oil change
check timing
check compression
RE: 60k Maintenance
When i hit 60k which will be like 2 weeks or so..
Full Fluid flush.. (coolant, oil, tranny fluid, diff fluid, brake fluid)
Plugs
clean air filter
new oil filter
new fuel filter
check all the hoses
Plugs
clean air filter
new oil filter
new fuel filter
check all the hoses
RE: 60k Maintenance
ORIGINAL: rbstang
Plugs
clean air filter
new oil filter
new fuel filter
check all the hoses
Plugs
clean air filter
new oil filter
new fuel filter
check all the hoses
09-25-2015 06:42 PM
