PROCHARGER STUMBLES NO BOOST!
Ok on my 2000 procharged GT I cant make any boost it stumbles when i try to make boost.If im invacum my car runs fine. I've changed fuel filter, fuel pump, plugs, cop's checked! fuel pressure @ 30-40psi. I have found oil in the pipes all the way upto the throttle body. Could it be my MAF?? if it has oil on it? Any help would be greatly appreciated.
Thanks.....
Thanks.....
RE: PROCHARGER STUMBLES NO BOOST!
Most likely your tune. Have you switched the MAF? And is your tune set up for your maf.
When I had a tune on the car setup for a different maf, it just flooded the engine with fuel anything over 2k rpms.
ORIGINAL: ^iLLuSiOn^
if you have oil in your tb i would take off intake tubes and check in the supercharger you may have blown a seal....
I'd start by doing a boost leak test.. Go around and check all of the couplers to all of your all of your intake plumbing... Then, if you think everything's good there, then start checking things like the throttle body gasket, and other things like that...
JT
JT
jwog666
12-27-2021 08:09 PM
TfcCDR
09-14-2015 12:08 PM
