Timing chain question
RE: Timing chain question
no try and get them as tight as possible, and when your oil pressure comes up the tensioners will correct for the slop. Take a big wrench and put it on one of the cams and move it, you will see that it will be loose in different areas as you move it. Try and get it as tight as you can , but if its alittle loose the tensioner will take car of it.
Hope that helps
Hope that helps
Here is some pics
http://i158.photobucket.com/albums/t...0410071538.jpg
Here is the passanger side sproket
http://i158.photobucket.com/albums/t...410071538a.jpg
Driver's side
http://i158.photobucket.com/albums/t...410071538b.jpg
Driver's side
It is official. I am a complete moron. I turned the passanger side cam and it took the slack out of it. Wow I should never be allowed near a vehicle again lol.
ORIGINAL: 00TropicGreenStang
Sh*t, that's how ya learn!
