anyone know wha t wires what on a mach 460 system, are the speaker wire going into the factory amps low level or high the rest i can probably figure out
I dont know if this helps much, but the wires you need are in the trunk. Fold down your back seats and lay on your back with your head in the trunk. They should be in between the black plastic and the seat bracket at the top. At least thats the ones i used when i put in my subs and amp. Hope that helps a little.
