How to get 300rwhp with an auto
RE: How to get 300rwhp with an auto
PI Cams and heads, longtubes, catback, udp's, tb and plenum, cai... most of which will only yield 1-5 hp gains except the pi cams and heads, and the longtubes. try an electric water pump as well
I say...
Hardballr intake
Accufab Plenum/75mm TB
Cold Air/Ram Air Intake
Underdrive pulleys
Handheld tuner
Ported PI headswap/Stg 2 cams
Full exhaust (long tubes if possible)
If you arent there yet you can always go with a set of roller rockers also. I think that all that would put you close. Try turning your compression up also that will help.
*Along with a good tune anyway
Hardballr intake
Underdrive pulleys
Handheld tuner
Think about getting a smaller diameter T/Cer, w/ an aluminum driveshaft too... Get a decent tune while you're at it, aiming for maximum timing on 93 Octane.. You must accept that you need to use 93 from there on in though..
JT
JT
mungodrums
09-28-2015 10:54 PM
