as long as you're over 30mph,just press 'on' and then 'coast'. if nothing happens pull the fuse. i'm not sure which one it is so check the manual
the coast button is like a temporary chill for CC i think, it turns it off. the middle button (cruise, on, whatever it is [coast is the third button down i remember that]) is what you wanna press (the raised button on the left side of steeringwheel to turn CC on, then the raised button on right [middle button]). mine has no light and works perfect as long as im above 25 mph. i can hit CC in 4th at 30mph and it works (5sp).
You have to be above 25mph and you can use it at pretty much any RPM. It may shut off if you go too low but I have had it on just over 1000rpms and it just bogs and really gives it gas trying to go.
