NO ONE HAS BEEN ABLE TO HELP ME FIGURE THIS OUT YET...LETS SEE IF ANY OF YOU CAN
Ok I have no idea whats wrong with my car, when i drove it last before it died it bogged like a flooding sound. And this started...I am getting fuel but no spark i have taken off the valve covers and timing chain cover but nothing is broke and the timing chain is a moves a tiny bit on the passenger side. i dont know if its the timing or what can anyone help me...can someone tell me how to reset the timing...if that is the problem... all woodruff keys are in great con dition i have changed the ECU and my alternator isnt hooked up if that makes a diff with spark....heres a vid....
Here is what it is doing------------- http://youtube.com/watch?v=rGXzfYJ0gBg
RE: NO ONE HAS BEEN ABLE TO HELP ME FIGURE THIS OUT YET...LETS SEE IF ANY OF YOU CAN
ORIGINAL: brent_cosenza
Youtube is down.
Might I also suggest you change the title of your thread to something pertaining to your problem...instead of a plea for help in Caps. If you can come up with a better title, your odds of getting worthwhile help or any help at all will increase...
As for help...your alternator won't effect your ignition. Your timing being off also wouldn't effect your ignition, it wouldn't fire properly but it wouldn't prevent any spark from occurring. You've been looking in the wrong places for your answer.You need to look at your ignition system.
ORIGINAL: 03_gt_woowee
you should go to autozone
LOL how the F' can he get to autozone if the car won't even fire up!?!? Jeebus people..think before just throwing shiz out there... [&:]
Besides AutoZone is great if you know what F' you need..otherwise they suck.
If there's fuel but no spark, it's ignition related. I would start with, how are testing for spark or how do you know there is no spark? Are you just going by the fact it won't fire up? Replacing the ECU would have been the LAST resort for fixing that problem. Could be as simple as a loose wire (bad ground) or a harness not connected.
i replaced the ecu because my alternator fried and i thought that might be the problem and the link does work and Dan i have the thread named other things but no one posted replies i got more out of this one and also my wiring harness is fine i checked my sparkwith a tester that i got from autozone lol...no fire
Okay so you have no fire. Is it all coils or just some?
If the alternator fried then it could be as simple as an ignition relay or fusible link blew. If you pop the plastic cover of the black box next to your batter you will find fusible links (look like giant fuses- solid body window on top) and relays (solid square boxes). Chances are you fried one of those.
you also need to check the fuses under the dash.
