WHICH INTAKE MANIFOLD TO BUY???
#21
RE: WHICH INTAKE MANIFOLD TO BUY???
here is a pi intake swap kit for 96-98 4.6's, it comes with everything you need. http://www.livernoismotorsports.com/...57&large=1
#23
well I would say easiest thing to do to if youre not sure about every little bit and peice then go with the kit I listed. Comes with everything but its a little more expensive.
#27
I like the idea of the Livernois setup. You put it on and let me know how it works out. I have to have my car pluged in every 2 years at the emissions station and that intake setup says "for off road use only". I'm sure it will give off fuel trim codes like mad.[/align]I also just talked to the local Mustang shop in my area and the guys there told me that these intakes that claim hp gains are full of it cause the heads on non PI cars can't support the extra air. So they tell you to get a tuner installed and that is were you will see the difference in hp gains.[/align]I amy just try and find a 99-04 engine assembly from a totaled Muatang. I'm sure I can find one in my area for under $1,000 with low miles.[/align]
panic
09-10-2015 05:56 PM
09-08-2015 11:50 AM
09-01-2015 08:16 PM
