For Those w/ Automatic Transmission
Idrovemy car around the neighborhood for 20 min. came back and checked my transmission fluid level andthe fluid levelwas at the end of C and none in the H section. Do I need to add some fluid?
Thanks
Thanks
RE: For Those w/ Automatic Transmission
C is for cold, H is for Hot I believe??? Mine seems to drop to NULL quite often as well. I'm thinking you should have it up to the middle of the H side after a 20 min ride. Least that's where I keep it.
ORIGINAL: ponyrideGT2004
Thanks
Thanks
Park the car on a level spot and don't turn the car off.
Move the lever through all the gears and then back to park.
Check the fluid with the car idling and it should be close to the H (hot).
If not, add a LITTLE at a time, and check it again.
As long as it is at or near the H when the car is fully warmed up, you should be fine.
