Torque specs for pinion bolt
I need to change my pinion seal because it is leaking alot of fluid, I was wondering the torque specs for the pinion bolt, and the drive shaft bolts. Also how many quarts of gear oil and what weight for my rear end.
RE: Torque specs for pinion bolt
if you didn't allready do it, you need a new crush sleeve. the crush sleeve is like a torgue-to-yield head bolt, but it crushes, so you cant reuse it. the back pinion bearing(front of car) will need to be removed. the only possable way to get it out is to pound out the pinion, so the diff would also have to come out. i dont think theres any other way. and at that point the bearing might possably be ruined. mine wasn't but i replaced it anyway. sounds like a good time to do a gear swap hint hint
minimum torque for pinion nut 140ft/lbs(i got up to 180 to get 20 inch pounds of bearing pre-load)
pinion flange bolts(driveshaft) 75-90ft/lbs
differential fluid about 2 quarts
good reads
http://www.corral.net/tech/drivetrain/gears.html
http://www.explorerforum.com/forums/...d.php?t=144780
http://www.superstallions.com/tech/d...ars/gears.html
good reads
ORIGINAL: bullitt15
The ford factory manual goes through the steps for replacing the seal without tearing down rear. They say to remove wheels & brakes then check the pinion rotational force with an inch lb torque wrench, that is the force needed to turn the pinion gear & ring gear & carrier & axles. Record that # than remove flange & replace seal then tighten nut (new nut recomended with locktite) until you can get a similar reading. I know this is not the procedure for a new pinion install but thats the way Ford says to do it. Now for the easy way, just remove flange & seal & reinstall flange & torque it to 150 ft lbs. Don't forget to top off your gear lube. It takes 250 to 400 ft lbs to crush that crush sleave more so 150 is enough to seat the flange & will leave everything the way it was as far as preload & depth. Any service station will do it this way in 1/2 hr. Many of us with 05+ stangs have replaced the flange to go to a one piece shaft and most have used this method without problems. Mark the flange & shaft so they go back the same way.
KingRando
10-02-2015 08:06 AM
