How to find exhaust leak...
Hi everyone, I put on my o/r h pipe and maybe I'm just paranoid, but I think I have a leak. Will this affect my performance? What is the best wayto find a leak? I think it is on my driver side by the header. Thanks for the tips.
RE: How to find exhaust leak...
a leak depending on how big should not affect ur performance. i have an exhaust leak from puttin on my o/r h pipe as well. the best way, if its at the headers, is to unbolt them and bolt them back up again evenly. like left bolt 2 turns then right bolt 2 turns and on and on.
ORIGINAL: gnutts
But I also have a major one leaking from the passenger side manifolds too. What does your sound like? Is it a ticking noise?..
you should be able to hear a exhaust leak, have someone give it a light rev while your head is down under the car. you could also start it up and put your hand around the connections and feel for a leak. or like said above look for condinsation leaks.
ORIGINAL: mvr
ORIGINAL: stangintheblue
is it normal to smell pretty strong exhaust fumes with an o/r mid? or is that caused by a leak?
Exhaust leaks doesn't affect your performance!? Where did u hear that? It may not be much, but yes it does affect performance! Fix it! NOW!!!If your racing and it's (exhaust leak) heard by your opponenet this what they'll do ----> [sm=laughat.gif], that means it'll befestering in your head, thus affecting your ability to think straight, thus affecting your perfomance to drive or race [8D]! Making you lose [&:]
Just fix it and feel better.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
