HELP! Rough idle and acceleration?!
So my car started idling rough a couple days ago. Today, it is bucking on acceleration and continues even when I get it up to speed. Any thoughts? Fuel pump? Plugs?
RE: HELP! Rough idle and acceleration?!
I just got over this problem. Here's what you're going to do, it's cheap just takes a little time and it'll knock out some important things.
First make sure all your ignition wires are pushed in all the way. Drive it around and ifstill bucks drive back into your garage and take apart your throttle body, IAC, and air intake.
Clean everything (including the filter, refresh it and reoil it if possible) - the IAC and throttle body. (Do NOT spray any cleaner into these, just wipe them down as well as possible and be very careful cleaning your MAF)
Drive around, if anything your car will run better but if the bucking / idling problem still exists go and get new spark plugs. Don't get anything fancy, 1 prong plugs are quite fine. No point in spending 6 bucks on dual or 4 prong spark plugs.
I highly recommend the fuel filter as well, I fixed mine by just doing the above but the fuel filter could be it just as much as what i just mentioned.
