new exhaust not loud
#22
RE: new exhaust not loud
i have a offroad x, long tubes, and borla stingers.... also heads,cams,blower.. so it will be pretty damn loud im guessing.. the cams made the car louder, and so did the blower under rpms with boost (more air going through exhuast)
#25
ORIGINAL: undecided.steve
FWIW I hate the sound of DRONEmasters .
They are noisy and obnoxious as well as being made like crap.
To each his own though!
to the thread originator, what do you mean by the magnaflow mufflers you put on sound like stock? my stock exhaust is beyond quiet. was your stock exhaust quiet?
#26
ORIGINAL: blownbayou
It is wierd that no one ever throws this out there......... Cut the rear cats off!!!!! You will get no CEL and your exhaust will go from a 4 to a 7 (loudness ten scale).
Trust me on this
Later
Trust me on this
Later
The rear 02 sensors are only inplace for one reason... to make sure the cats are working.
As I said before, try some dumps. They are really cheap, but if you don't want to pay before you try em just crawl under the car and pull the rear pipes off the mufflers, then try driving around. My car is still fairly quiet inside at cruise but louder at idle and way louder at WOT.
#29
If you remove the rear cats without using a MIL eliminator or a tuner to turn them off the CEL WILL light up, its only a matter of time.
#30
ORIGINAL: CobraStangGT16
changing your tips can change your tone????
I've never heard of that before.
It's a fact, Ichanged the tip on a lx, 5.0 after removing the stock mid piping and welding in high flows with Flowmaster muffs (regular shifting and down shifting set off car alarms),and on the 02 gt changed the tips after welding in the catted x and packs for a more aggressive tone.
The Pack's cat back come with 3.5 tips its for more than just looks.
