So I Cleaned Out My IAC.....
Old 04-13-2007, 04:25 PM
cdefftone33
Default So I Cleaned Out My IAC.....
I have a problem with stalling, and i cleaned out my IAC, to no prevail! Oh well, seemed like it wood work! I wanted to ask you guys, what is the BLACK **** on top of ithe IAC for?? It doesnt adjust squat! I read in my manuel that the IAC is adjusted from the factory and if you beleive it has been tampered with, take it to a shop that has a "SCAN" machine. Well, if anybody has any insight, let me know and thanks alot!
[IMG]local://upfiles/65011/85D10974122645379917586732979FCA.jpg[/IMG]
cdefftone33 is offline
Old 04-13-2007, 04:42 PM
richinwa
Default RE: So I Cleaned Out My IAC.....
The black know is useless!
There used to be a IAC plate availible from the Ford dealer but i don't think they still make them anymore.
What you may want to do is 1st disconnect the battery (to reset idle stradegy) then remove and clean the throttle body and then retest it. You should also check for vac leaks, that is the #1 cause of the issue that you are having.
richinwa is offline
Old 04-13-2007, 04:44 PM
Ryan86272
Ryan86272's Avatar
ORIGINAL: richinwa
+1 Check for a Vac lines, The stock ones get hott and Flemsy and they Collapse...
Ryan86272 is offline
baddog671
07-26-2016 01:20 PM
EZFEED
05-05-2016 08:54 PM
Dathan
10-05-2015 05:52 AM
4cylinderplus2
09-30-2015 05:26 PM
folivier
09-26-2015 02:28 PM
Quick Reply: So I Cleaned Out My IAC.....
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
