Another Track Night...
So as you know I did horribly last weekend, but I think I improved ALOT...my average time was a 14.7
60'= 2.4
330= 6.29
1/8= 9.53
I think I dont get as well times as others if because where I live..which is in tucson az...
60'= 2.4
330= 6.29
1/8= 9.53
RE: Another Track Night...
"Well...it seems like Ms. Melissa seems to be alright....well errmmmm shes walking around in frustration? alright, the crew has checked her out! SHES ALRIGHT EVERYONE!!!" hahaha
You need to invest in some drag radials. I was running consistent 2.0 and 1.9 60's on street tires. For every tenth in your 60 is two tenths at the end of the track(correct me if I'm wrong)
Your 60's are simply horrid. Are your tires completely bald? Even just letting it out and pinning the throttle should result in a better 60' than a 2.4.... you must be popping the clutch and spinning really bad?
Try this next time: Just bring the car up to aroud 2000 RPM, and when the light goes green slowly/moderatly let out the cluch while brining in the gas. Try to keep the RPM around 2000+ until the clutch is all the way out. When the clutch is fully out you should be at WOT.
What this usuallyi does for me is give me a good jump off the line but still not spin the tires. You get WOT the entire way thru 1st without tirespin, and it usually results in around a 1.9 60' for me... you should see atleast 2.1s or 2.2s doing this.
^^But....I wanna say this is the guy who was getting 3.0 60 ft. times last week. 2.4 Doesn't sound too bad at all for a weeks work
2000GT, what track do you go to? Is there a closer track for you than GIR?
