pi swap vs pi motor
pi swap vs pi motor
From what I have read a pi swap costs at least a grand for parts. I have seen pi motors go for less that this. Would it not just be cheaper and easier to swap in a pi motor. I feel confident i could swap a motor, as i have pulled the motor on tranny on other vehicles, but would not be to sure about actually tearing into the engine. What are your guys opinions about this?
RE: pi swap vs pi motor
yeah me too so i was just wondering why you would do a pi swap when you could just swap the entire engine. With the entire engine you would also be safer for boost with the lower compression. I just think that it would be easier to sawp the entire engine. This is of course if everything bolts up, such as the tranny and wiring harness??
ORIGINAL: jst854
the added power of the pi swap over the pi engine is minimal from what i understand?
the little bit of compression the Pi heads give a 96-98
ORIGINAL: 00TropicGreenStang
Yeah I heard that too. Why is that?
ORIGINAL: xxkazp3rxx
I hear you will actually see more power off of a pi swap then a pi motor....
