Corner carver or drag stang?
RE: Corner carver or drag stang?
ORIGINAL: Aereon
I am into corner carving, just finished installing the first part of my suspension (coilovers, c/c plates, lca's) 2nd part of the suspension installation is gonna happen but just hafta find the time to get the parts from my room to underneath my car (torque arm and panhard bar). Thing is if you wanna think your badass going straight and a miata can eat you up in a turn.. how does that make you feel?=P
I think for the average mustang owner its a lot easier to go fast in a straight line. Thats why some people are so supprised to see high dollar imports getting beaten by mustang and camaros in a stright line. Thoes cars were ment to go around a road course. Outa the box the ferrais, lambos, and porsches were ment to handle like the F1 cars.
Now personally i would much rather go fast in a straight line becasue theres really no place around here, except for route 66 that i can use a road course. As opposed to a strip monster when you can stomp it at every light.
ORIGINAL: 1BadSonicBlue02GT
Thats like comparing two completely different things. stick a miata against you on the track and eat it up. run on a course and get beat.they arejust two diff things. *if its a good miataanyway
ORIGINAL: Aereon
And Jdavis, the main difference is in where the spring is placed and the adjustability of it. I am currently slammed, my tires are into my wheel wells and I have about an inch clearance from chin spoiler to the ground, all it takes for me to go back to regular ride height tho is a quick twist of the collar and I can go 4x4'in again.. If you have the car setup right you may not need to have it aligned right. Also the coilovers place the springs on the shocks and struts, lowering unsprung weight (which is the best weight to lose) Relocating the springs makes the car feel much better, even with pretty stiff springs, my ride quality has increased dramatically.
I have 225lb front 325lb rear H&R coilover springs,MM hd bilstein shocks/struts coilover kit w/shocks and struts, MM caster/camber plates, MM extreme duty LCA, MM heavy duty torque arm, and MM panhard bar.I have the rear quadshock and the UCA's will be removed once I have enough time to finish installing the Torque arm and Panhard bar.
ORIGINAL: Aereon
