Corner carver or drag stang?
#21
RE: Corner carver or drag stang?
Did the lowered, 18 polished bullits and nice handling thing...of course it rode like ****z...I'm 37 and it got old bouncing around hitting and feeling every crack and bump....so I'm headin the other direction...drag car style....15x 10 prostars in the rear 15 x31/2 in the front and M/T Drag radials 275/50/15 in the rear and stock ride height.....gonna do some more UMTR racing....itswhole lots of fun...Code....hope yeah dont mind,,if I copy you abit....you inspired me
#23
ORIGINAL: notch5oh
i went the same route, but with tokico hp shocks/struts/springs andno torque arm, i alsofabed a 4pt. roll bar and k member brace.The choice to make my car corner fast was based on the fact that it had a 5 speed instead of an auto, if it was an auto i'd be at the strip all the time
ORIGINAL: Aereon
I have 225lb front 325lb rear H&R coilover springs,MM hd bilstein shocks/struts coilover kit w/shocks and struts, MM caster/camber plates, MM extreme duty LCA, MM heavy duty torque arm, and MM panhard bar.I have the rear quadshock and the UCA's will be removed once I have enough time to finish installing the Torque arm and Panhard bar.
#24
ORIGINAL: jdavis
is there a paticular rim size to give optimum handling?
#25
ORIGINAL: jdavis
Ive noticed most lean toward the drag stang or at least ETs. not much mention of the corner carvin performance. What are u guys opinions?
Not into the dragstrip scene, but I enjoy watching and learning about it.
Different strokes for different folks.
#27
If your just modding your DD I wouldnt do what I have done.. its more suspension then you'll ever be able to use on the street.. (safely)
Coilovers are really nice tho, a cheap setup costs about 700, more developed ones like griggs and mm's are close to 1500 and come with shocks/struts and cc plates
#29
http://www.youtube.com/watch?v=AzpDOFOvdek
This is what a mustang with good suspension can do.. if you were in a mustang with a stock rear 4 link and just some loweing springs you wouldnt be able to accomplish this with such ease.. look at his hands!
#30
That's what I am going for is a carver. This is what I want for Christmas
http://www.stangsuspension.com/store...?idproduct=931
