problem with MGW shifter
i put in my MGW shifter in my 02 GT today and everything is fine. exept there is alot of movement and play with the shifter when it is in any gear is this normal? i am not supposed to use shift stops right?
RE: problem with MGW shifter
ORIGINAL: pistolpete837
yea when the old shifter came out it stayed put
No you got it right, mine is totally locked up in gear...
Did you order the right shifter for your tranny year? It's the 3650 right?
Try installing the old shifter on again, and just snug everything down, and check if you still have movement. If you don't call up MGW and ask them what you should do.
GOD NO he didnt.. dude listen to me carefully.. take the MGW out, GET THE BALL OUT OF THERE!!!! Put it on the end of the MGW - then reinstall, and it'll work fine... you can actually damage your tranny like that... seriously. Per George @ MGW.
ORIGINAL: CobraStangGT16
