Last edit by: IB Advertising
Browse all: Interior Guides
- Ford Mustang GT 1996 to 2014: Factory Sound System Information
Guide to diagnose trouble and recommended solutions
mach 1000 sound system
does anyone know how many watts each of the mach 1000 amp's in an '03 gt would be?
i was thinking about buying subwoofers to go along with the amps, but wanted to make sure the amps were at least a good wattage, that would be worthwhile to add subs.
thanks!
thanks!
RE: mach 1000 sound system
Here is some Info I found. Hope it helps.
Technical Specifications
[*]One high-pass amplifier with 60 watts C.A.P./120 watts peak power at 2 percent total harmonic distortion[*]Two low-pass subwoofer amplifiers with 85 watts C.A.P./170 watts peak power[*]Four additional MACH MA185 amplifiers[*]Six 5.5 inch x 7.5 inch subwoofers
[*]Two rear-seat woofers[*]Two front-door woofers[*]Two MACH 10 inch subwoofers in integral 14-liter sealed enclosures mounted in the trunk [/ul][*]Four 2.5 inch midrange/tweeters[*]Works with existing factory head unit [/ul]
09-10-2015 08:39 PM
