Owners Manual
Owners Manual
I have a 02 GTand my headlights were working fine yesterday and then last night i tried to turn on my lights but they didn't come on my taillights and everything else worked. I checked my fuses and even changed both bulbs but they still don't work any suggestions? what this could be could it be a relay? Does any one know what fuse is for the headlamps?
RE: Owners Manual
Not the fuse, first take a look at the headlight switch connector, they sometimes get too many amps and burning the connection. You will notice right away if that is the problem cause it will be all distorted and brown like it is burnt. If that is not the case then replace the multi-function switch.
RE: Owners Manual
I gotthis info out of my **2004 owners manual. Check the internet for a manualfor your year. That's how I got mine. Hope this helps you...
**10A for right-hand lowbeam headlamp located in fuse box
**10A for left-hand low beamhead lamp locatedin fuse box.
**20A for your high beams in the fuse box.
**30A for headlamps located in your Power Distribution Box
lincolnshibuya
12-08-2015 04:37 PM
BeatnikFink
10-01-2015 08:00 PM
