97 Supercharged Cobra Cutting out
Old 04-22-2007, 04:33 AM
blown_cobra
blown_cobra's Avatar
Default RE: 97 Supercharged Cobra Cutting out
What is a boost leak?
blown_cobra is offline
Old 04-22-2007, 04:36 AM
Maverick04GT
Maverick04GT's Avatar
ORIGINAL: blown_cobra
It's simply where air is leaking out....for the problem you're looking at, it'd probably be a leak somewhere in the intake system between the MAF and the motor itself. First things first though, did you get it tuned when you installed the blower? If not, that could be your problem right there.
Maverick04GT is offline
blown_cobra
What actually is a spark blowout? A guy locally told me that could be the problem. What should my plugs be gapped at witha supercharger?
Old 04-22-2007, 04:38 AM
blown_cobra
I bought the car from a car lot with the supercharger already installed, so I'm not sure if it has been tuned or not.
Old 04-22-2007, 04:40 AM
blown_cobra
It has always cut out ever since I had the car, but once I installed the msd coils it seemed to cut out even worse.
Old 04-22-2007, 04:51 AM
breagles
breagles's Avatar
I have the same problem . It is your tune . I need to get mine dyno tuned also . I think on a blown mod motor the plug gap is .035 . I had a fuel leak in my fuel pump on the dyno when I was tuning mine so I couldn't finish my tune (don't ever go to the hot rod store of Texas to have a fuel pump built) . After I got it fixed at Murillo motorsports I scheduled an appointment for another dyno tune ,but it wasn't for a few days . So I drove it anyways figuring I'd take it in when the time came . I raced an 04 cobra and won but blew the motor in the process so take it easy on it until you can get it tuned. Don't do what I did .
breagles is offline
Old 04-22-2007, 02:11 PM
GodAmGT00
GodAmGT00's Avatar
Since it got worse when you installed a new Ignition, I'd say swap out the plugs for some decent ones, and I bet you'll be good...
JT
GodAmGT00 is offline
Old 04-22-2007, 03:19 PM
blown_cobra
What type of plugs should I use with a supercharger?
Old 04-22-2007, 03:27 PM
contentsunderpressur
contentsunderpressur's Avatar
Get a set of NGK TR6s and gap them at .032. I had the same problem with my 03 gt and my friend had the same problem with his blown 97 cobra. You must have non-platnium non-iridium plugs and the gap is the most important part. If your at 12 psi or lower go .032 gap, 13 to 16 psi go .030 and 17 up go .028. My friend with the 97 cobra has 18 psi and blew the spark out with a .035 gap. He went to .028 and hasn't had a problem since. Once again, the gap is very important on a blower car.
contentsunderpressur is offline
Old 04-22-2007, 04:04 PM
blown_cobra
you said non-platnium non-iridium plugs. I have some copper core plugs with a power tip made by autolite, would that work?
Quick Reply: 97 Supercharged Cobra Cutting out
