Twin cobra pumps???
Twin cobra pumps???
Im installing twinn pumps from an 03 Terminator in my stock GT tank. Does anyone have any info on this? Is it a direct bolt in or will there need to be fabrication done. Also, will I have any restrictions? I was told that I will not be able to run when the fuel level is below a half tank due to the absence of baffling that is in the cobra tank. If I did, it may starve for fuel and run lean. Any info guys or evidence to back this statement up?
RE: Twin cobra pumps???
HANEY MOTORSPORTS IS IN THE PROCESS OF BUILDING ME A 302 SHORTBLOCK SO I DECIDED TO GET THE PATRIOT PERFORMANCE STAGE 2 HEADS, AF-52 BLOWER CAMS, PROFESSIONAL PRODUCTS POLISHED LOWER INTAKE AND NEW BILLET FUEL RAIL, COBRA HIGH VOLUME OIL PUMP, CANTON 7QT OIL PAN AND WINDAGE TRAY AND ACCEL COIL ON PLUG COILS. I HAVE ALL OTHER BOLT ONS ALREADY AND I BUMPED MY BLOWER PULLEY FROM 3.60 TO 2.87 WHICH VORTECH SAID SHOULD YEID 15-16 PSI AT ABOUT 48,000 RPM AND BE AT PEAK EFFICIENCY. IM SURE THAT THE TUNE AND TEMPERATURE DOWN HERE IN MIAMIWILL PLAY A LARGE ROLL IN MY MAX POWER. IF IM IN THE 500 AREA I WILL BE SATISFIED.
Thanks for the info. I picked up the cobra pumps off EBAY for $230 used, hope they work good. If not Ill be spending even more dough. Damn this buildgot expensive on me. I couldnt help myself once I got started ordering ****. Its a sickness man.
