Supercharger+Gears???
RE: Supercharger+Gears???
ORIGINAL: stang2000
Then definately don't go with 4.10's since most of the time you're shifting sooner and you're not going to hit your prime RPM peak.
ORIGINAL: stang2000
I was under the assumption the higher the gear the sooner you're shifting in a manual!
A 4.10 will be shorter than a 3.73, but the 4.10s should be ok in his cobra with that redline.
i got 3:90s and a V2, i luv em, just make sure you got sticky tires for first and second gear othewise its gonna be a burnout. but once you hook up its like nothing youve ever felt
ORIGINAL: 2000GT4.6
You will, but he has a higher redline. You don't have to shift at 6200~ with the cobra, he can run it out to 6800, which means more time in the gear.
ORIGINAL: stang2000
ORIGINAL: stang2000
Well I was mis informed for sure, lol My bad. I do still lik my 3.73's though. I guess since it's not a major hard core track car, it's good enough for me.
