Pissing Me Off
Old 04-22-2007, 01:42 AM
immencedata
immencedata's Avatar
Default Pissing Me Off
I got a 2000 Mustang Gt and every once in while when coming to a stop the rpm's drop low and sometimes it stalls not all the time though. I took it to a Ford dealer and had test ran and it came back that the IAC was bad, so i replaced it with a new one. Still same problem i also replaced the TPS, PVC, took throttle body off and cleaned it throughly, still does it. Can someone please help me out everyone says the same thing IAC but it isnt. No check engine light is on and also i cleaned off the MAF sensor to. New o2 sensors about a year ago spark plugs all clean cant hear any air leaks and sealed every place possible. Thank You
[IMG]local://upfiles/23589/EA6DCAF724274902B1EFA1EABECE2277.jpg[/IMG]
immencedata is offline
Old 04-22-2007, 01:45 AM
sprostang
I ♥ Acer
sprostang's Avatar
Default RE: Pissing Me Off
Clean the injectors and change the fuel filter..... Maybe.
sprostang is offline
Old 04-22-2007, 01:47 AM
immencedata
Sorry i am new to working on car were are the injectors sorry it is probably a stupid question but i approciate it.
Old 04-22-2007, 01:48 AM
01GT4.6
01GT4.6's Avatar
try this 1st, disconnect the battery for about a 1/2 hr and see what happens then.
01GT4.6 is offline
Old 04-22-2007, 01:49 AM
immencedata
Me and my buddy did tat it was unplugged for a hour pumped the brakes to drain it totally and reset the trim still same thing.
Old 04-22-2007, 01:51 AM
sprostang
I ♥ Acer
sprostang's Avatar
ORIGINAL: immencedata
Pretty much next to the spark plugs. You will see the fuel rails going to each injector. You can have them cleaned or run a can of BG-44 K through the gas. Thatshould help.
Old 04-22-2007, 01:54 AM
immencedata
Shell V Power does tat doesnt it
sprostang
I ♥ Acer
sprostang's Avatar
Yeah but not as good.
Old 04-22-2007, 01:56 AM
immencedata
ok what is the brand or is that what it is called
Old 04-22-2007, 02:00 AM
sprostang
I ♥ Acer
sprostang's Avatar
Thats what it is. BG-44 K. Search google for it. It`s $20 per can.
Chances are you mayhave another problem though but this should help out. When did you change your spark plugs and fuel filter last??
Quick Reply: Pissing Me Off
