White smoke??
White smoke??
White smoke has been belowing out of my exhuast for like a week now, someone said something about it at firt and I thought it was just moisture. Today after my oil change I noticed it. It's mostly at idle and goes away during a free rev, either that or there is so little that it just blows it out of sight if you know what I mean. What is this and how do I fix it?
-Thanks
-Thanks
RE: White smoke??
I've heard of this being burnt coolant fumes. It's happened to me once before, but only out of my driverside pipe? That was RIGHT before I blew my spark plug. I doubt it has anything to do with it, but check if your plugs are tight and functioning just in case.
RE: White smoke??
ORIGINAL: CobraStangGT16
RE: White smoke??
ORIGINAL: oxfordgt
White smoke is coolant. Get down and smell it if it smells sweet then its coolant and probably a head gasket.
RE: White smoke??
ORIGINAL: 97targa
Not necessarily, but most of the time! You can have blow by and to most it appears "white" unless you get a real good look at it or get up against a white car to see the blue. If it's not coolant (head gasket or head prblem) then it's most likely a valve stem seal! They run like $30 at local parts store and take about 5 hours to do! You can still have super high compresion and have either ring or valve seal problems also. You really need to do a leak down test to properly diagnos the sitiation
ORIGINAL: oxfordgt
