TECH: Oil pressure restriction! No oil to heads! HELP!!!
Old 04-24-2007, 12:17 PM
96GT226410
CSMG Moderator
Default RE: TECH: Oil pressure restriction! No oil to heads! HELP!!!
I took off the valve cover on the passenger side, unplugged the coil packs, and cranked the engine. Should oil make itto the top of the engine with only the starter turning it over? Should doing that pump up the lifters? While cranking it, only a very small bit was dripping out. It could have been coming from the journals, I couldn't get a good look at it. Anyone know? Thanks...
96GT226410 is offline
Old 04-24-2007, 01:18 PM
oxfordgt
oxfordgt's Avatar
Have you ran it up to 2000rpms? I just built my motor and had ticking from the lashadjuster. After I ran it at 1200rpms I ran it up to 2000-2200rpms and the ticking went any and never came back. That is the start up prcedures for a ne engine but will work for you.
You shouldnt get enough pressure to get the oil up in the heads just by cranking it.
oxfordgt is offline
Old 04-24-2007, 01:34 PM
96GT226410
CSMG Moderator
I've had it up to 3,000 RPMs before. With the valve cover off, I just started it and shut it off after 2 seconds.
Old 04-25-2007, 04:13 PM
badboystangGT
i'd say change out the lash adjusters!
badboystangGT is offline
Old 04-25-2007, 04:18 PM
96GT226410
CSMG Moderator
I may do that, too. Especially since I ran them dry for about 20 minutes.
bconboy
09-21-2015 12:52 PM
SteelerNation82
09-16-2015 07:11 AM
EASTIDEE123
09-15-2015 11:08 AM
EASTIDEE123
09-14-2015 03:52 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: TECH: Oil pressure restriction! No oil to heads! HELP!!!
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
