Supercharged GT OIL IN SYSTEM HELP!!!
Old 04-23-2007, 09:59 PM
Noe2big
Noe2big's Avatar
Default Supercharged GT OIL IN SYSTEM HELP!!!
Hey need help on an issue i'm having with my00 Procharged GTi am getting alot of oil back into my intake pipes,intercooler andthrottle bodyand it is coming from the driver side valve cover that has a hose that connects to the intake tube at the supercharger I am getting alot of oil from there. I tried a oil seperator but the oil still makes its way through would an oil catch can be a better option? if i disconnect the hose from the valve cover it just steams like a tea pot. So please help me.
Thanx
Noe2big is offline
Old 04-23-2007, 10:29 PM
Noe2big
Noe2big's Avatar
Default RE: Supercharged GT OIL IN SYSTEM HELP!!!
anybody??
Noe2big is offline
Old 04-24-2007, 09:12 PM
Noe2big
Noe2big's Avatar
no input???
Noe2big is offline
Old 04-24-2007, 09:14 PM
2002GTAUTOVERT
2002GTAUTOVERT's Avatar
sounds like some bad gaskets or rings, usual cause for oil appearing in unusual places, id start there. are you burning any oil off out the exhaust?
2002GTAUTOVERT is offline
Old 04-26-2007, 07:27 PM
blown_cobra
blown_cobra's Avatar
What its doing is your valves are splashing the oil around and its collectingin the hose from the valve cover to the inlet tubeand the S/c is sucking it through to the t/b. Just about every aftermarket supercharger will make you car do this. How's your oil level? The steam that is coming out is probably caused by blow-by,just about every ford that comes out will have a some blow-by, but if you have a lot of steamthat is usually caused by supercharger or turbo applicationwhen your running high boost. Just keep an eye on your oil level and you should be all right.
blown_cobra is offline
Old 04-26-2007, 08:42 PM
99StangGTTN
99StangGTTN's Avatar
It is normal mine does the same thing. I was told you can get a oil separator if it is a lot of oil..
99StangGTTN is offline
Old 04-26-2007, 08:53 PM
lizzyfan
Underboss
lizzyfan's Avatar
ORIGINAL: 99StangGTTN
Same here!!
Make your own oil seperator for about twenty bucks from Home Depot!
lizzyfan is offline
Old 04-26-2007, 08:56 PM
lizzyfan
Underboss
lizzyfan's Avatar
https://mustangforums.com/m_2281950/tm.htm
lizzyfan is offline
Old 04-26-2007, 09:05 PM
Frostbitten
Frostbitten's Avatar
just about everyone s/c'ed has this same problem. Its nasty on mine too. Does anyone notice a swirling pattern to oil in there? It looks like it was slung from the impeller but theres no oil spitting from it. A swirling pattern all the way down the powerpipe. Oil in the intake charge increases the chance of detonation. Make sure you use reinforced braided stainless lines on the catch can setup. Itll suck those rubber hoses completely shut.
Frostbitten is offline
Old 04-26-2007, 09:12 PM
lizzyfan
Underboss
lizzyfan's Avatar
I rigged one up with an aircompressor oil/water filter, works great!
It is a common thing with either twin screw or centri.
lizzyfan is offline
Quick Reply: Supercharged GT OIL IN SYSTEM HELP!!!
