Went from Off Road X to Prochamber
So, i got my Prochamber on today and i had on the UPR Off Road X. I'm not too sure about it. Way softer sound and doesn't really have the " bite " in it when i rev it. Although, it's only been one day, i will still give it some time. I might keep the Off Road X and do a Dyno on both just to see the HP difference.
RE: Went from Off Road X to Prochamber
ORIGINAL: chachi
Well, there are always Dyno Days at a shop and i would do one early with the Prochamber and then switch and then do the Off Road X later. I switched because the UPR just really sucked. Was leaking where the pipe hooked up to the drivers side header. And everyone talks so much good things with the Prochamber, so i thought i would give it a shot.
I went from a bassani X to a prochamber and I like the prochamber better. The difference is a prochamber makes sound that would rattle things off the walls of your garage because its so deep, while the X makes a sound that would just make you go deaf.
