A/C delete
RE: A/C delete
Well I’m not necessary deleting it permanently. I’m keeping the canister and everything. I’m just taking out the lines because they blew when my long tubes were rubbing on them. Well now I’m converting to an 8 rib set up and the A/C compressor is the only thing left that is still 6 rib. I can ether find an 8 rib pulley for the compressor or an elimination bracket that has one until I can find one.
RE: A/C delete
ORIGINAL: czwalga00gt
I'm considering taking mine out, it doesnt work so might as well. There is a leak somewhere, i put 134a in itll last me about 2 weeks then back to heat.
RE: A/C delete
Ebay has some brackets that you can use, its just a pulley on a bracket.
You would probably spend less finding a local CNC and bringing in your old AC pulley and one of the accessory 8 rib pulleys and having them custom make you one. I couldnt see more than $30 bux for one if you shopped around. You should also ask the company that made the 8 rib ones if they can supply you with one for the AC.
-Eric-
-Eric-
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
