procharger #'s are in
RE: procharger #'s are in
yeah it's off. thats what we thought it was at first. then we turned it off, took it for a ride and it was fine. i dropped him off at the shop and left. a couple miles down the road i started getting on it again and when i'd shift from second to third it boggs for a split second. but everything else on it is great. the pull from 60 to 120 is incredable. i havnt been able to truely see what it's capable of down low yet because of traction problems. what kind of numbers are yo guys putting down? what can i do to improve mine to around 385? and any other advice would be appreciated.
ORIGINAL: stoes
ORIGINAL: stoes
can you explain to me how a clutch would effect performance? orbe the reason for a bog? and what kind should i look into?
I just put in a centerforce dual friction.... I dont think a clutch will cause it to bog. Think about it if the clutch grabs to soft the motor will rev up due to the clutch slipping. I do know that the stock clutch wont handle the power. My clutch and my buddies clutch both went out within a week of putting it on. So you may as well change it.
