Name that axle...
Name that axle...
ok so here are 2 axles, one is clearly in my car the other isnt, and i need to know what each one is. and i have a GT but dont say its an 8.8 unless you know from the pics it is.
first, what is this??
Second, what is this?? i dont think its from a mustang (check out the brackets)
RE: Name that axle...
They both look like 8.8's. And unless someone turned your car into a serious drag machine earlier in its life (highly doubtful) you do not have a 9" rear end. The other just looks like it came out of a truck but just as easily could be out of a Mustang. Those big brackets are just wherecontrol arms bolt on.
ORIGINAL: ASUSMC
They both look like 8.8's. And unless someone turned your car into a serious drag machine earlier in its life (highly doubtful) you do not have a 9" rear end. The other just looks like it came out of a truck.
i know the second is not a 9" i know what they look like, but what i think may have happened is someone swapped in a 7.5 to save money cuz they blew it up. the second was from a junkyard and the brackets look somewhat similar to whats in the stang but there seems to be some extra **** on it which is making say its from something else...a truck like you said perhaps.
ah you edited your post on me lol. look at those flat brackets, they look like leaf spring perches, and there looks to be coil spring cups on the axle, not where the control arms should be.
oh yea and the azle is upsidedown on the gorund so you can barely see the spring cups im tlaking about
ORIGINAL: weasel1088
will tell you the difference between the 7.5 and 8.8
That second axle looks like it's out of an older mustang that used quad-shocks. Those brackets are the quad mounts. They were used before lower control arms became standard.
