Mass Air
Mass Air
Do I need to change my injectors if I go with a bigger Mass Air? I have the BBK 75MM Throttle Body and High Flow Inlet Plenum in the mail on it's way as I type.
On another note. How the hell can I put a pic of my stang with my question e-mail? I tried and it said the FILE WAS TO LARGE. Please advise.
RE: Mass Air
the only reason you really need a bigger MAF is if you're going some type of f/i, and if thats so, you'll need bigger injectors anyways.
go to www.photobucket.com make an account, load your pics on there, and post the link in your sig.....
RE: Mass Air
you really only need more injectors when you get more hp. There is an equation for fuel injectors. If you have full bolt on then you should be fine with 19s maybe 24s if you wanna get motivated for some more power. But you just have to make sure that you tune everything.
